ORIGINAL: 2Sunny
ORIGINAL: J Lachowski
Joe you should be able to remove the rudder to make it easy for you. I just taped straight epoxy stirring sticks and lined them up.
Thanks!
While I've got your attention . . . how long do you push your packs typically on a practice run? Right now I'm going 8 minutes 30 seconds and only putting 3000 to 3500 mAh back in so I'm thinking I might try pushing it to 9 minutes. Any thoughts?
Joe
P.S. Can you shoot me a PM with your email? I'd like to hear more about your experience with the micro-Suhkoi. I'm thinking about buying one keep thinking its a waste of money.
I have my timer set at 8 minutes. I just usually land after a complete Masters sequence. Don't go any higher, you are just shortening your battery life. Remember the temps outside are cool now, so your packs don't feel too hot.
As for the Sukhoi, save your money unless you want to do a bunch of mods. Check this link out for info on mods etc.
http://www.rcgroups.com/forums/showp...89&postcount=1
