RCU Forums - View Single Post - Need a fuel tank for a VooDoo
Old 10-07-2009 | 01:13 PM
cutaway
Default RE: Need a fuel tank for a VooDoo
The tank I made looks the same general shape as the Brodaks mentioned. Feed tube exits top sheeting, and a pressure tap vent exits near the forward inboard top corner angled to the front at about 45 degrees. I tip the outboard wing down to fill and let it overflow out the pressure vent.
If I had to do it again, I'd add 2 more vent lines for fill/overflow (capped after filling) so I wasn't always removing the feed and tap lines to refuel.
