ORIGINAL: gerhardp
Hi Carsten,
Thanks for the reply, When you get to know whether or not it works and what the limitations might be, I'd be interested in getting to know the results.
Gerhard
Hi Gerhard,
I did not find any support whatsoever for the Multiprop feature!
IF the text on the datasheet for the big receivers points to the support for MPDX-10 module, someone else has to test it, I have no MPDX modules here, and honestly I think it's irrelevant if it works or not, whats the idea of using a nice "powerbox type" receiver as the 12-22 and then attaching a box with tiny wires, and no power redundancy etc as all the servo ports gives you on the 12-22 ???
I'm puzzled why they didn't simply add the Multiprop support inside the receiver, they must clearly be able to do the same decoding internally in software as the MPDX is doing inside !
I flew with the Micro 12 and my 14MZ yesterday, data is in Olivers (olnico) thread about the "Weatronic RF tool"
But so far, the biggest problem is the total silence from Germany, I REALLY hope Rob is soon getting some response !!
