ORIGINAL: hillbillyexpress
Thank you for the great pics, the problem is that i already have installed the push rod for the throttle and epoxyed the pushrod tube, so i dont think ill be able to flip the throttle are on the carb, is there a way to flip the arn on the choke ?
The only way is to grind off the braded end and remove the arm and install an arm like what you would use on the front of a nose gear plane.
http://www3.towerhobbies.com/cgi-bin...?&I=LXD847&P=0
