RE: Kyosho Osmose 70, Sort of build thread (slow..)
SynergyPilot,
You will need a lot of throttle management since FS110 will be way over powered for the plane.
Stock gear may not have enough ground clearance for anything longer than 13". (stock setup is 13x6) I am using Bolly F3A carbon gear on mine that is taller than stock.
It may become too fast even for landing since the FS110 will need at least 13x9 or higher pitch.
You may want to beef up the LG plate mounting also.
Good luck,
