The ocean
well I ran man backdraft .3.5 at the beach today. I did a short little test run everything was fine went down to the beach made to small little laps around the truck then it just takes off full throttle Tottal loss of control. I goes 100 200 yards before it runs in the water. I finally get to it and I turn the switch off and look at it and the throttle is stuck wide open I cant even push it shut. I go home and take apart the motor its all good except that every time i go to put the backplate and the pull start on the pull start wont pull I take it off and everything moves freely I am assuming that the backplate is getting put on to tight? the second part of this why did I loose complete controll of my car it was like 20 ft from me when it took off had brand new batteries in rec and radio. Now if i turn the car on nothing happens no respose not even a twitch. Dont know where to start with this one
