RE: Scale Toggle Switches
I rolled the tips of stick pins in thick CA and hit it with accelerator. Then sanded the CA the shape of a toggle. used my dremel to spin the pin. Painted, and pushed the other end of the pin through the dash and glued it from the back side. You could use any diameter nail or solid wire you needed for your scale size.
