RCU Forums - View Single Post - Venus II
Thread: Venus II
Old 10-10-2009 | 01:49 AM
  #1293
CustomPC's Avatar
CustomPC
Default RE: Venus II
After over 6 months on the building board i have finally found the time to finish my Venus II and plan to maiden her tommorrow, weather permitting.
I was planning to use my Webra .91 but decided to go with the 1.20AX instead. I'm using a Turbo-Jett muffler which fits completely within the cowl. I used Dubro ball links on all control links and made my own pseudo carbon push rods by using some carbon tube over 4-40 threaded rod glued in with a small amount of gorilla glue. These are much stiffer than the metal rods and only add a few grams of weight.
Servos are Futaba 9255's on the Ailerons and Elevators, 9151 on the Rudder. Power is provided by a PowerBox DigiSwitch and Fromeco 2600mAh LiOn pack.
The dry weight is 3,900gm (8.59lb)
The balance came out almost perfect. I only needed 15gm (1/2oz) of lead weight near the tail wheel to get it on the reccomended CofG.
one thing that concerns me is that the landing gear has quite a bit of toe-out and i'm wondering if this will effect the taxiing at all?
ID:	1291770   Click image for larger version
ID:	1291771   Click image for larger version
ID:	1291772   Click image for larger version
ID:	1291773   Click image for larger version
