RE: Scale Toggle Switches
Now that is what Im talking about!!!!!! Im pretty sure at 40% you could actually use the Mini toggles that Radio shack sells and they would look just fine. Im impressed by the full cockpit and the tubing to simulate the fullscale construction. But he needs to give Patty a Haircut and a bleach job to keep up with the times ;-) One thing Ive been thinking about, consdering the fact the when these panels are observed, the model is sitting on the ground, so to me it would make sense that the RPM gauge would be at Zero, as well as the Airspeed, and the Altimeter should show the elevation of whatever the person is calling their home base (or in the case of a aerobatic airplane thats used to perform O') WHen the gauges should show anything other than those readings the model will be in the air, and no one can see them..
