RE: futaba 9z
Have you tested your DR settings on another model in the radio? If another model's DR works without shifting center, then it is probably the programming for the model where you are experiencing problems. If the DR shifting problem occurs on multiple models, you may need new pots in the 9Z. If I remember correctly, the shifting center is a symptom of worn pots in the TX.
Woodie
