RE: SATURN SE
you are a 100% correct on those changes. I will supply the cores with the ailerons taper. It will be up to you if you want to cut them off and build them out of tri stock, unless you give me directions otherwise.
This weekend was our Thanksgiving long weekend and i spent most of monday working on the mold. It will be all good, can't
wait to pull one out. Two layers of 6oz should do it.
Phil
