RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 10-13-2009 | 10:44 PM
  #5793
unit53
Default RE: DL-50 engine
man,,,that could be anything from loose engine bolts or firewall to the allen bolt that secures the spinner ,off balanced prop ,bent prop stud ,off center crank  failing bearings,whew,,,you got alot to check,unless its obvious,if you havent had any prop strikes or crashes,,,,its easy ,not to look for off balance/center,then all of a sudden you check,i found a off center crank  on another motor,that way,ive noticed on my 50 ,,that theres a hair of endplay ,if one was to move the prop up and down,check yours.
