RE: Noo start, ignition timeout
I've had this happen twice. Everything appeared normal and it ran fine the last time out. The plug did glow but not like it did when new. I use the Rossi plug as recommended by Jetcat. Replacing the plug on both occasions got me up and running.
As KC stated, the clicking sound from the gas solenoid is normal.
Try a rossi or mccoy plug and ditch the no name plugs for your turbine.
BTW, you are modifying your plugs by pulling two coils out right?
