Noo start, ignition timeout
My Feedback: (14)
Engine worked flawlessly last weekend. This Sat on first start attempt I got "ignition timeout" on first 3 attempts. 4th attempt the gas solenoid started clicking and sounded like the sparker from an old pulse jet. finally got a start on 4th attempt, but got long flame tail from butane.
I'm thinking solenoid is bad, but would like confirmation before replacing. Have you guys seen this before?
My Feedback: (14)
Well, with Red Flag days and Navy business it's been a while since I've had a chance to work with this. Got it out this weekend and tried to start. As soon as the ignition kicks on the gas valve starts going click, click, click. Just keeps clicking on and off 2 - 3 times a second. Butane dumps and ignition times out. Unplugged the solenoid from the ECU and put 4.8V directly to the plug and solenoid just clicks one time to on, unplug the direct 4.8V source and solenoid clicks off. ECU battery is fully charged.
Am I seeing a solenoid problem or an ECU problem?
Check the plug, had [link=http://www.rcuniverse.com/forum/m_8982371/tm.htm]similiar/same problem[/link] with mine and although it was glowing it wasn't igniting the gas, new plug solved it for me.
My Feedback: (14)
Did try a new plug (actually several), but they were cheapie, no name plugs I had left over. Let me try once more with a good plug.
Never heard it go click, click, click before it started with the ignition timeout problem, so not sure this is normal operation.
ORIGINAL: s3nfo
i assure you this is normal operation, the clicking is the ECU's way of regulating gas flow, the higher the gas flow percentage the faster the clicks.
SC
I've had this happen twice. Everything appeared normal and it ran fine the last time out. The plug did glow but not like it did when new. I use the Rossi plug as recommended by Jetcat. Replacing the plug on both occasions got me up and running.
As KC stated, the clicking sound from the gas solenoid is normal.
Try a rossi or mccoy plug and ditch the no name plugs for your turbine.
BTW, you are modifying your plugs by pulling two coils out right?
