RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 10-15-2009 | 04:00 PM
  #5815
mstam1971
Default RE: DL-50 engine
ORIGINAL: PlaneKrazee
mstam1971,
Do you own or have access to a dial indicator? After you pull the propdriver you can check the crank for run out. .002 should be the max. The original propdriver on my DL was .0075.[X(]
No I don't.
Got myself a strap wrench but it's not holding up so I'm gonna need to make a metal tool to hold the prop hub. See if I can get a dial indicator. Strange that this issue seems to be new or else I would have had noticed earlier.
The clicking sound is a mystery. There are no metal parts left, bearings look fine, no play and no grinding.
ID:	1295510   Click image for larger version
ID:	1295511   Click image for larger version
