RE: 14mz issues(when switching different conditions )
Some further check RESULTS are as follows:
I double checked my setting. V1.3.2 sw(Latest SW).
SW C is a 3-position SW, you know(we can name it P1,P2,P3. Here P=position).
Of course, any other 3-position SW can also be used.
Detailed setting:
1)In normal condition, SET:
P1= Ailerion D/R on*,ELE D/R on,RUD D/R on (all small).
P2= Ailerion D/R off,ELE D/R off,RUD D/R off (all large).
P3= Ailerion D/R off,ELE D/R off,RUD D/R off (all large).
*As an example, D/R on=50% ATV, D/R off=100% ATV
2)In arco condition, SET:
P1= all D/R off (all large).
P2= ailerion D/R on(small),ELE & RUD D/R off(large)
P3= all D/R on (all small).
3)SW C is condition switching SW too. P1=P3=normal conditon on. P2= Arco condition on.
From setting above,the final result shouled be:
P1:Normal condition. All D/R on(all small).
P2:Arco condition. Ailerion D/R on (Ailerion small only).ELE & RUD D/R off(large).
P3:Normal condition. ALL D/R off (all large).
Pls check 14mz by 3 steps:
1, Ailerion,RUD & ELE Jog/servo center position. Operate SW C among 3 positions quickly for about 10 times.
2, Ailerion max position (either left or right is OK).Operate SW C between P1 & P2 quickly for about 10 times.
3, Rudder & elevator max position. Operate SW C between P2 & P3 quickly for about 10 times.
I find unexpected SERVO action (ill movements and viberates in very short time during such a condition changing process), and
at the same time I find abnormal servo state display via SERVO MONITOR menu of 14MZ.
By the way, I have 2 14mzs(ALL V1.3.2 SW). The earlier one (No.000030xx) tends to happen this strange thing. But the other
one with series number 000111xx never. I have checked another 14mz(000018xx) of my friend, it is also often.
I guess there may be some risks with early 14mzs (for example, less than 3000 ?) .
If your 14mz's number is less than 3k, I suggest you to check it by process mentioned above.
