RCU Forums - View Single Post - Pilot RC Extra - DLE 30?
Old 10-16-2009 | 11:13 AM
ro347
My Feedback: (13)
Default RE: Pilot RC Extra - DLE 30?
ORIGINAL: beachbrada
You've got the 46AX right?? Then you can definitely use that engine on the OMP Pro Yak, its got enough power to get you going. And the Saito 91 might be overkill on power, but its still light enough to not make your plane a lead sled. Just run a 15x4 with it and will be golden. So you could use either of those engines. A profile is definitely the doorway to 3D.
Yes a 46AX. So you think that the profiles have actually improved your flying in terms of 3D? I guess it doesnt make sense to go bigger and better, yet still be at the same skill level. Ill give it some consideration over the weekend for sure.
What servos are you using? Do you think they are ideal?
