ORIGINAL: ats909
Thanks Silent.
Another Informations:
1) I tried all other 3P Switches, the radio performed abnomally all the time.
2) If I disable P1 & P3 in arco condition (In other words, all D/R NA with P1 & P3 in arco condition. You can check POST #5 comments), the issues DISAPPEAR. (Of course the D/R logic is not changed: P1 all small, P2 ailerion small only, P3 all large )
So I think there may be some logic or circuit issue with my radio. However, I still believe it is not single but may be a common issue with some 14mzs due to circuit or driver SW bug.
Thanks any way, I will send it to Futaba service center.
Hi again,
As has been mentioned, this is the issue that worn out pots cause. This is also the reason you are seeing this on your servo monitor screen. Sending the unti in to your local service center will correct the problem.
Steve
