ORIGINAL: mstam1971
So what you're saying is that the bolts need to be 5x65mm? Where did you get the longer bolts from? I recently ordered some stuff from RTL fasteners which has been shipped already so can't add to the order.
I need to place an order at Valley View so will include 2 stacks.
Martin I didn't actually measure them when I was done but I first cut them down from 70mm to 65mm. Then I had to trim them down a few more mm since it was bottoming on the crank counter balance. What you can do is just get them 5x65mm and trim them down with a dremmel. It's easy enough. I'd say more like 62-63mm.
I got mine from Fastenal.
These would work:
http://www.fastenal.com/web/products...0135910&ucst=t
