RCU Forums - View Single Post - CG issues
Thread: CG issues
Old 10-18-2009 | 08:35 AM
Lnewqban's Avatar
Lnewqban
Default RE: CG issues
Is this your model?
You can not balance it straight up, position for which it is unstable; it is not that the CG is too sensitive.
I suspect improper thrust angle here.
Did you note any difference in behavior between full power and idle?
Are flaps active? If so, did you note any difference when using them?
