RCU Forums - View Single Post - improved vibration
Old 10-18-2009 | 02:44 PM
andi3142001
Default RE: improved vibration
Hi Glen,
do you have an older version of the SP? On the ones sold now they changed the gear, never owned an old version but it seems to make a difference.
I run an 120SP now for 3 seasons, and would not say that there is a difference regarding vibrations compared to other fourstrokes.
They all shake
What I do believe is a difference is the doubled torque, that tries the engine to distort on the bulkhead. If the screws are not tight enough and the engine gets some play things get rough. I had to reinforce the bulkhead, it really has to be rock solid as any weakness will result in movement and loose screws.
Cheers
Andi
