RE: Max Battery
What aspect of using a higher capacity battery concerns you?
As long as the higher capacity battery fits, and as long as its greater weight doesn't hurt performance too much, it should work fine. If it's the weight that concerns you, find out the weight of your proposed larger battery and add some weight to your current setup to see how the heli performs with the additional weight.
- Jeff
