Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Max Battery
Old 10-18-2009 | 06:42 PM
Default Max Battery
I need to know just what batteries I can use in the Blade 400 Heli. It comes with a 3S 11.1V 1800mAh battery and I want to know if I can use higher mAh batteries for longer run times. jskelly@lsav8r(dot)com replace the (dot) with .
Old 10-18-2009 | 08:00 PM
jdetray's Avatar
Default RE: Max Battery
What aspect of using a higher capacity battery concerns you?
As long as the higher capacity battery fits, and as long as its greater weight doesn't hurt performance too much, it should work fine. If it's the weight that concerns you, find out the weight of your proposed larger battery and add some weight to your current setup to see how the heli performs with the additional weight.
- Jeff
