rx-18 board problem?
hi,
i was just testing my second metal hull early tiger I and just finished the metal upgrade.. when i was running it here in my living room the "sound" sddenly stopped.. but the tank still running, only the sound just stopped.. so when i switch it off and was trying to start up the engine sound again.. nothing happened and the head light is just steady (not blinking while in stand by mode)
then when i pressed the start on the control just a few seconds the tank started to move just like the regular HL tank (nonsmoking and sound) and it wouldnt switch off whe i pressed the off switch on the controller..
i took everything apart/disconnected all the wires then recconnected it.. and switched it back on. i dont see any blinking light on the headlight but i could hear a crackling sound in the speaker.. very very low crackling sound.. but the tank wouldnt start and theres no blinking head light... i dont see any smoke or burns on the board..
just want to know if the problem is the rx-18 board or something else? just want your opinion before i would get a replacement board..
thanks
daryl
