DP Ultimate 120
The plane flies as advertised! Very docile. This is my first 3D capable plane, and i think it is just a tad underpowered w/ the 150 saito. I might try the os 160. I've read on here that quite a few people are using the 160 with very good results. I believe my plane is a little heavier then normal tho. I'd say all up weight has to be pushing 12lbs. I need to get her to a scale. I'm spinning a 16x8 apc prop at about 8600 rpm. I need more stick time thought to better asses things. You will love the plane though it is beautiful.
AL
