RCU Forums - View Single Post - DX-5E buttons
Old 10-19-2009 | 05:45 PM
blitzkrieg65's Avatar
blitzkrieg65
Default RE: DX-5E buttons
ORIGINAL: blitzkrieg65
ORIGINAL: edoubleaz
Goal of the button is to make the radio think you have thrown the trim forward momentarily. I located the leads and soldered some some spare wire to the contact points. Also I connected the leads to one of the loops on the switch.
Be careful and use heat sinks as to not melt the button or the contacts on the radio. I must now locate a receiver for this project as my Br6000 won't Bind.
What do you mean you cannot bind it too the BR6000? Does it work, and are you saying you are cutting into the 3 movements that goes off the left stick and the elevation still works fine?
Phil
Hey Ethan,,
How did this turn out, and can you explain it a little better please.
Phil
