RCU Forums - View Single Post - Another Skymaster Viper
Old 10-20-2009 | 09:24 AM
  #258
Jim Cattanach's Avatar
Jim Cattanach
Default RE: Another Skymaster Viper
Started fitting out the fuselage today. The front equipment tray is not much use, as the front cockpit tub almost reaches the top of it. I didn't fit it. I used the space for the three air tanks.
I made up a new board & fitted it between the tanks & the fuse joiner. I shortened the rear cockpit tub by about half an inch, as it doesn't fit in the space provided between the tank & the fuse joiner. Still some work to finish off the equipment installation, but it's going well.
ID:	1298603   Click image for larger version
ID:	1298604   Click image for larger version
