RCU Forums - View Single Post - Build thread for a Carl Goldberg Eagle II Trainer??
Old 10-21-2009 | 09:57 PM
KitBuilder's Avatar
KitBuilder
Default RE: Build thread for a Carl Goldberg Eagle II Trainer??
I have been working on the second wing and it is at the same pt of completion as the first. They need to be joined, bolt on wing option put in place and top center sheeting with the glassed center section.
I wanted to start the wing mounted servos but found I did not have the ply I needed in my scrap []. So I started punching out the fuselage pieces and gathering everytihng up. Building the fuselage has always been my favorite part of construction. After puncing out the pieces for the lightening holes in the fuse, I found I did now have the pieces I needed. . I didnt tihnk about the lightening hole scrap. So I bagged up the now loose fusleage formders, etc and started on the servo mounts. The pic shows it taped in place but you can see what I'm going for. The ply will fit snugly between the ribs with the servo mounted on its side. It will screw into hardwood supports and I usually box it in as well. I add hardwood supports on the ribs for the square-ish mount to sit on and be screwed into at the 4 corners. I have used servo mount screws in the past with no issues. The opening needs to be fine tuned still for arm movment. I use mini's as they only have a few ounces less torgue than standards but since they're driving only one aileron it's not an issue plus they're easier to fit. Hope to get those both completed tomorrow evening.
ID:	1299730   Click image for larger version
ID:	1299731   Click image for larger version
