RE: 12FG Function menu prog question
Bax,
Thanks - the reminder that I only need one AFR for each of the two functions was also helpful. I experimented with the elevator and assigned T5 to the elevator 2 trim and found that T2 still moved both elevator trims while T5 only moved the one I has assigned it to. I can see where this could be very useful if you needed to move just one servo trim. I have more questions but, first I will try to find the answers myself thanks.
Howard
