ORIGINAL: jaav
Jewy did you have a problem with the fuse crushing? or did you beef it it up??
I've noticed the fuse near the motor gets real floppy when the motor gets hot. So far its only pushed in when I nose in hard but I'm sure it moves around while in the air. I did wrap some tape around the motor area to try strengthen it. Maybe wrapping the back end of the fuse in fibreglass sheet or epoxy would do the trick.
