RE: Glowplug starter with 12V input ???
The easiest thing to do is to replace the battery... and you can buy a couple of them together...
Most of the power panels have a glow plug output, and you need a glow plug clip.
Direct 12V over the glow plug burns it in no time.
There are still possibilities...
Use a series resistor....
Use some electronics to reduce the voltage... or to generate a PWM with an average voltage around 1.2V...
I would look first for a battery...then a cheap glow starter.... (I bought one for 7EU)...and then for a power panel....and so on..
