RCU Forums - View Single Post - Electrafun XP Review/Thread!
Old 10-24-2009 | 10:59 PM
  #2050
jaav
Default RE: Electrafun XP Review/Thread!
Crashed the Twin slight damage...Engine thrust was uneven or wing problem all she wanted to do is drop the left wing..
then I heard the note of the engines change out of sync, then lost control...One of the ECS battery plugs came off and that was the one for the RX....In to the wet mud.
The Spad EX dart was very diferent after upgrade 6.3.4. Was'nt taking the wind to good. did some hard turns and loops then a hard landing had to drive it to the ground as it would float. Missed the vid footage, pressed the wrong FCO button..The 2nd flight was out of control it would roll over and was very unstable untill she did a perfect nose dive at speed in to the ground..Just as well the mud was wet.....Nice imprint of the nose cone and leading edge of the wing, gives you an idea how far she crushed.....Cause of the crash main spar was broken. Must have cracked it in the loops and the hard landing..Most of the landing on this are bellys or flex UC..This had steel struts.MMMMMM.
So I fired up the sons SPA3D. this is the 1st time Ive had fun with it. The bloody landings! with very strong winds it would just float..After the 3rd try I put her down on its tail in a semi hover...
The Thrasher came out speed sensor fitted, with diferent props then an all out with a 3 cell uncontrolable, all on vid.
