RCU Forums - View Single Post - Flap Servo
Thread: Flap Servo
Old 10-25-2009 | 07:43 AM
RCISFUN's Avatar
RCISFUN
My Feedback: (44)
Default RE: Flap Servo
All Hi-Tec digital servos have the capability to have there speed programmed, did you verify the settings on a Hi-Tec programmer?
The Hi-Tec HPP-21 is a handy tool and it is relatively inexpensive.
Also (as a test) can you mix two separate channels together to verify the servo operation on independent channels to eliminate any possible influence that Y may have on the operation.
As mentioned, it could be as simple as the geometry of the linkages
Edit - I see you checked the linkages
ID:	1301456   Click image for larger version
