ORIGINAL: combatpigg
The CG range of this .061 powered plane is the thickness of my pinkies.
How did you figure that range?
The simple method only gives one point.
To get a range would require something that uses the Static Margin desired? The simple method really doesn't consider anything more than the wing shape.
