ORIGINAL: Matt Chapman
One issue im still wondering about: Using Futaba 2.4 and the Air Power EVSD-5U-PRO-ST . When i turn the radio on the first time, the gear cycles up, then down once. Shut the radio off after that an turn it back on... it works ok. More anoying than anything, but any thoughts?
Matt Chapman
i think your problem is that the receiver was binded with the gear switch in the up position, Rebind your receiver with the gear switch down.
basically your failsafe is set for gear up and when you switch the system on it momentarily goes into failsafe and that will make the gear go up. i hope this helps, this is what i did when my gear was doing the same.
