RCU Forums - View Single Post - Composite-ARF Integral, kinda build thread
Old 10-28-2009 | 07:26 AM
  #928
Jeff Boyd 2's Avatar
Jeff Boyd 2
Default RE: Composite-ARF Integral, kinda build thread
ORIGINAL: DaveL322
JAS,
Sorry for the brief high jacking of your thread........
Jeff/Ryan,
I am not a composites expert by any means, and consider my CF laminate props a bit crude (but effective). I'll not start another thread, as what I do is brief to explain -
1. Roughen prop with 240 sandpaper
2. Cut 4 pieces of 3.5oz 24 thread per inch CF cloth (CF-141, http://www.cstsales.com/carbon_fabric.html)
3. Coat prop blade w/ thick CA, lay on 1 piece of CF cloth, ''squeegee'' CA through cloth using plastic baggy wrapped finger. Add CA as needed to ensure CF cloth is saturated, soak up extra CA w/ paper towel
4. Repeat for other blad surfaces, trim excess, lightly sand w/ 240.
5. Brush clear expoxy to fill weave, wetsand 240 between coats, and repeat until smooth surface is obtained.
That's it. I extend the CF cloth as far onto the hub as I can, with varied degrees of success. Clearly this is modifying the prop and potentially changing the stresses at the hub, and I don't know how this might affect the longevity of the prop. Thus far I have several props that are between 100 and 200 flights with no problems, and I've done this on several prop sizes including 11, 12, 13, 19, 20.5, and 21'' props. For the pattern realm, my best estimate is that adding CF will have little benefit on a 21'' prop turning less than ~6000 RPM, or on a 19'' prop turning less than ~6700 RPM. Certainly vacuum bagging would be a better technique, but I've not ventured to learn that process to date.
Regards,
Dave
ORIGINAL: Jeff Boyd 2
ORIGINAL: Ryan Smith
Dave,
Do you use tow or cloth when you're laminating the props? I assume you go down to the hub as well? I really liked how Quique's props worked at the WC and it seems as though you can gain a lot of performance with slight adjustment.
A new thread on ''CF Laminating APC Props'' would be GREAT . . or at least a couple of pics )
Cheers, JB
Thanks Dave . .
Sounds good. While I have had great success with APC props generally, I have thought the larger APC-E props to be a little too much on the flexible side for good efficiency (I'm NO expert, it's just a observation).
The APC range makes it a little more palatable (from a cost stand-point) to test different Dia. and Pitch, and trim and repitch and whatever . . I am thinking that testing different props and CF "stiffening" a preferred prop might be an option (and a bit of fun ;o).
Would I be correct in assuming that it would make a preferred APC-E prop BETTER ?? OR does the additonal stiffness change things? e.g. a pitch dimension less when carboned, etc. ?? What has been your observations ?
I have no idea what kind of additional stresses, in use, would be placed on the prop AFTER CF stiffening. One thing for sure . . I would hate a blade to decide it's had enough, and 'part company' [X(]
Maybe APC will bring out a range of E-Pattern props Carbon Reinforced ?? ! ? . . CAN YA HEAR ME, APC ??
Cheers, JB
