RE: JetJoe OWNERS thread
PS - silly question I suppose, but you did remember to 'prime' the Kero system - yeh?
You have to make sure that the fuel line has solid fuel in it from the the pick-up from your fuel source through to the solenoid (if you're using one), fuel pump, and then all the way to where you see the fuel-line go into the Turbine - no air bubbles.
If you've got great gobs or air anywhere in the line the Turbine will spit and fart and carry on like a pork-chop...
