RCU Forums - View Single Post - Problem problem problem
Old 10-29-2009 | 05:47 PM
Kostas1's Avatar
Kostas1
Default RE: Problem problem problem
ORIGINAL: dalolyn
do you have your fuel tank hooked up to the pressure tap on the muffler.
Guys,
the engine is used,not new,
and according to the owner it is also run in.
Using the APC 11x6 i get a good "slow" idle,
even at full throttle,
with the nose at the usual position,engine works fine,
Only problem is when i put the plane verical.
I have the 3-line setup on the fuel tank.
One for filling,
one for the muffler,
one for the needle valve[]
