RCU Forums - View Single Post - prop rpm question??
Old 10-29-2009 | 09:46 PM
ro347
My Feedback: (13)
Default RE: prop rpm question??
Saito 91 on showtime 50 at about 6.5lbs.
Wondering if static thrust is equal...or just about.... is there a benefit to the higher rpm range?
So far ive run:
an apc 14x7 at 9000 rpm(calculated 9.77 lbs of thrust) ,,,
and 15x6 xoar at 8400 rpm(calculated 11.22 lbs of thrust)
also wondering if i should be looking for higher peak rpm - am i putting too much load on engine with 15x6?
