RCU Forums - View Single Post - Problem problem problem
Old 10-30-2009 | 02:12 PM
Vacaman
Default RE: Problem problem problem
You may have a loop on the clunk line, inside the tank, and its against the front side.
Also, some time ago a friend of mine had the same problem on a engine that he bought used. The engine had a screw inside the muffler, after the baffle. When the engine pointed up, the screw jump to the exit hole and shut the engine off.
