RCU Forums - View Single Post - Fuel Dot on Plane with a COWL (Not sure of Setup)
Old 07-03-2003 | 05:16 PM
hookedonrc's Avatar
hookedonrc
Default Fuel Dot on Plane with a COWL (Not sure of Setup)
P51-B: Do you mean that I will see the overflow out of the back of the muffler? Reason that is ask is the way you describe the set up is exactly what I use. By your statement it sounds like you look at the tail end of the muffler if you don't remove the line to the muffler itself.
