RCU Forums - View Single Post - Problem problem problem
Old 10-31-2009 | 05:22 AM
estradajae
Default RE: Problem problem problem
If you use a larger prop on an engine you should use a colder glow plug, a hotter plug may make it worse...though the A3 should be the right with the 10x6 prop.
