RE: engine mounting
I always get the arms flush against the case, that is the only way at times to have enough material between the mounting hole and the inside edge of the mount. If need be I'll cut/grind the mount to clear any part of the engine that prevents this. I don't think you can get an answer as to an exact measurement as the variables are to great, including exactly what the mount is made of.
