RE: My Tiger 1 keeps throwing treads!
Wow where do i start , Tracks to loose , more likely to much movement on the drive sproket- does it move when wiggled with yoiur hand. Make sure you have no loose track pins. There will be a reason as they dont throw tracks for no reason. the fix for loose drive sproket is to look closely at your gearbox , it can be tightened up there or you can add a piece of aluminium on the outside of the hull with a 8mm hole in it for the drive shaft, screw or glue it on after popping off the fake gear cover on the outside . Tony
