RCU Forums - View Single Post - plane for tower .46?
Old 07-08-2003 | 01:31 PM
boneman_66
Default plane for tower .46?
thanks for the tips geo. you mentioned earlier not to use a Y harness i'm guessing that means running the airleron servos on separate channels and using a cpu radio to mix? i've got a 9caf so that's not a problem - just wanted to make sure i understood you correctly.
also - never changed the engine thrust before - is that a strong recommendation or something at the margin that could be done down the road - outa planes right now so kinda looking to get it up and flying as soon as possible heh.
should be here tomorrow - i'll let you know how it goes.
thanks again,
boneman
