RE: Beveling Basics help
I do this by marking the centre line of elevator edge then marking the top and bottom to give the desired angle.
Using a razor plane [ if you do not have one go out and BUY ONE NOW ] with the cut set very thin it is an easy job to plane to the lines and do a neat job. The key is getting a good job is getting the plane set to just remove a very thin cut and eyeballing the job as you go.
