RCU Forums - View Single Post - Beveling Basics help
Old 11-01-2009 | 09:07 PM
ChuckW's Avatar
ChuckW
Default RE: Beveling Basics help
I use a similar method. Mark the center of the surface LE then where I want to angle to on the top and bottom. For larger surfaces I may use a plane or hobby knife to remove some material then follow up with a sanding bar and 80 grit. On thinner surfaces I just use the sanding bar. Coarse sandpaper cuts through balsa like butter. Sometimes as I get it close I will switch to a finer grit.
