RCU Forums - View Single Post - Another Skymaster Viper
Old 11-02-2009 | 05:06 AM
  #347
Duncan's Avatar
Duncan
Default RE: Another Skymaster Viper
Hi Murray
Here are the pics of the rudder mod, making it removable for travel, it's only a 20 minute job (after the hysol has dried). I first drilled a hole under the stab and in line with the metal clamp which holds the rear carbon rod in place. Then on the inside of the fuz i added a fillet of hysol either side of where the front ali peg sits. Then with the rudder in place and locked by the rear clamp, i drilled a 2.5mm hole in the side of the fuz and through the ali peg. This was then tapped to 3mm and a countersink ground, so the 3mm bolt sits flush with the fuz when in place.
hope that helps
Duncan
ID:	1306530   Click image for larger version
ID:	1306531   Click image for larger version
ID:	1306532   Click image for larger version
