RE: Balancing a canard or tandem wing biplane for initial flight.
Here is a little experiment, build a flat panel canard glider in the proportions you intend to use out of balsa or even cardboard weight it for the proper cg location.
Toss it and see how it flies, then set it up tail heavy and try it again, quick and easy, you will see what happens.
