RCU Forums - View Single Post - Homelite 30CC carb
Old 11-05-2009 | 07:18 AM
dszabo2
Default Homelite 30CC carb
I have a 30 CC homelite blower engine which runs fine at idle but dies when you give it the gas. Rebuilt and cleaned the carb but still wont run right. There is no high speed needle and the only numbers on the carb are WYC. I mounted a WA229 carb and it ran Ok however I had to turn the HS needle way out and seem to run hot. I also think the bore on the WA229 might be on the small side Can anyone tell me a better carb to use? .
Thanks for the help.
Dave
